Jon Boat Leaking
shogle
Hello,<br /> I had my Jon boat out today and for the first time I had water coming onboard, so when I went home I filled the bottom of the boat up with the hose and found that one of my rivets was leaking. How would someone go about fixing the leaky rivit in a standard jon boat?<br /><br />Thanks ahead of time<br />Scott
D
DJ
Guest
Re: Jon Boat Leaking
Tighten the rivet up as best as you can. Hold a block on the inside and strike it from below with a hammer.<br /><br />You can then seal it with a product such as Gluv It or 3M 5200.
