I have a jon boat similar to Knobby, a 14 x 36, to which I added a raised deck and foot trolling motor which has worked fine. It is a 1974 Fisher with a 1972 20 HP Johnson. The motor is a long shaft on a 15" transom and it sprays a lot of water, I'm not sure if that is the reason. The boat is rated for max 20HP. I am considering replacing the motor with a new one. The new 15 HP are the same weight class. Would I lose a lot of speed if I downsized to a new 15 with the correct short shaft?
