Need some fatherly Advise. Can some please help me on this I am frek'n lost!!!!!
<br /><br />I need a wiring diagram to meet the following needs. I know I am not the only one here, I have seen lot of posts in the past and in several message boards asking very vague questions but here is the ultimate.<br /><br />I would like someone to build me a wiring diagram that meets the following criteria. I want to install Bow/Stern light, bilge pump w/ switch, live well, and a cigarette light type receptacle for spot light. I want a toggle switch panel to be mounted on the rear bench for easy operation. <br /><br />#1 question which battery to use crank(rear) or the troll battery(front)<br /> <br />#2 Where can you get toggle switch panel that would meet this need. Or similar (need web address) <br /><br />#3 size wiring to use?<br /><br /># Need fuses and where to install those?<br /><br />Can someone give me the break down on wiring a Jon!!!!!! <br /><br />Thanks<br />Jason
