Dont worry, you are not alone. I have had many of these leak on me.
If your carb drips fuel all the time, you have a float problem. This could be due to a stuck/corroded float pin, float too heavy,etc...
If it only drips when you press down on the primer pump, then you need the leather primer seals. (yes I said leather). These are available from an AOMCI member.
In fact, read this, it will help and save me some typing, lol.
I got overzealous coating my TN float with dope, and dunked her 4 times thinking the more the better. Forgot that I was adding weight, and all I got was a leaky carb to due a heavy float.
I have had a few with seized float pins as well, but that is all covered in the link provided.
