1982 merc 90 H.P.inline 6, Engine has jumped timing marks from 6:00 clock position to 1:00 clock position looking from front of engine.Will not start,was running ok on muff before this time jump thing.I turned flywheel clockwise until piston was 0.464 inch(12mm)BTDC". pointer was aligned with .464BTDC mark on flywheel as manual stated, no change.Advancing or retarding manually while cranking makes little diference and does not get my marks near the pointer so I can get the corect timing marks aligned. Was hoping someone could tell me what my problem could be and what to do to remedy this.Thanks
