Robert Gross
- Mar 3, 2016
- 4
Re: Water in gear oil 72 mercury 650
You will have to get a the special tool and pull out the carrier set up and replace the seal. If thats the only place its leaking then the prop shaft seal and a O ring is all you need.
Hi new at this, know this is an old forum, but hope you can still help. What tool are you talking about. I have the same 1072 650 and one day it just started jumping out of gear when i gave throttle. I replace the prop, still bad. people told me it was worn forward gear and clutch. Took lower unit off but can't don't know how to get the gears out. Also this all started when a guy "fixed" my control linkage at motor. Any answers?
