Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
My tachometer jumps at various rpms at all speeds on my 1999 evinrude ficht motor. Is this due to a defective tach or is something else in the engine causing this problem.
I would look for loose connections,
start behind the tach, remove and reinstall wiring or plug.
Check connections at the rectifier,
spray elec cleaner on the main harness plug contacts too.
Check battery connections, no wing nuts.
