jimphillips
- Jun 12, 2013
- 8
A little backgrounAbout a month ago, I replaced the water pump impeller and reassembled. When I started the first time, it ran fine. The second start clunked loudly and then the starter would only spin. I took the starter off and had rebuilt. Assuming I had hydrolock I also replaced the plugs (no sign of water) and checked the oil(no sign of water there either). After the plug replacement, the boat started and ran perfectly. A day later, all I get is a soft click when trying to start. I checked and retightened all connections. I also replaced the slave solenoid on the top of the motor. Still just a click. Any ideas?
