Just a little throttle makes the engine sputter and die (reverse too) - but jumping on the throttle it runs great
Then, after a good half hour on the water - the light throttle is just fine and no issues
this never happened before the mechanic took the engine out to replace the timing cover
Happens on the trailer just like the water
When in neutral - idles great.
When shifted into forward gear or reverse - runs/idles great
but as soon as the throttle engages and starts to open up - massive stuttering and will die unless I punch it or pull back, then runs great.
I do not think its a dirty carb, I think something is just out of place or needs adjusted
Here is some pics of the side of the carb - its weird the carb is always open?
and after the top latch comes down w/ the throttle going forward, it never goes back up...?
Also a video of my giving it some slight throttle here
https://youtu.be/ozNdA40X_U8
any suggestions?
i hate to pay big bucks, especially it works well when full or even half throttle (then works normally after a good 30 min on the water)
any help would be greatly appreciated
any suggestions?
