Pageracing1
- Jul 1, 2008
- 10
I just bought my first bass boat. It is a 1985 Skeeter Starfire 115 with a Johnson 120v4 engine on it. I bought it from a local guy that said it had been rewired recently and that the engine had been rebuilt as well. He put all new coil packs on the engine along with new wires, plugs, fuel lines, fuel filter..etc.
My questions are involving some switches and wiring. I took a picture to show the switches that I'm talking about at the front of the boat. I know that the trolling motor needs to be replaced because when I hooked up all the wires it would barely turn. Also when you turn the prop by hand it feels like it's almost locked up and squeals when turning. I know the one plug is for the trolling motor to plug into. And right beside it is a switch that says charge 2 12v and run 12/24v. I'm confused as to what that switch does and how it works. The switch feels like it should be replaced as well and I don't know where to get one at.
Beside that is the aerator switch and tilt up and down which works properly still and then there is the broken courtesy light which I can't find a replacement for either.
Basically everything else works fine with the exception of the trim up and down switch on the throttle control needs to be replaced soon. The switch still works currently but it's about to break by the feel of it.
Also I have several other various questions:
How much fuel does the gas tank hold?
What is the best 2 stroke oil to use with this engine? (Johnson V4)
How do you turn the idle down on the engine? (It idles high enough to make noise when you put it in gear)
How fast should this boat run?
Thanks in advance for any advice given.
Here are a few pics of the boat and the switches I am referring to.
