Just bought my first boat, and after extensive research and testing the boat I purchased the boat today. What a feeling, but I am still a novice when it comes to owning my own boat. Was curious if this forum could help me with some of the basics. The Motor has about 40 Hrs on it and looks to be very clean. Even though it is 10 years old.
Engine Questions
1) Would it be wise to replace the original spark plugs after 10 Years of being in the motor. When I test drove it, the engine kick on after the second turn of the key, but when we turned it off 10 Min later and talked a little it took about 7 to 8 Seconds for it to kick on. Should I be worried and have it serviced?
2) How often should I replace the gear oil?
3) How long can you have gas in the tank before it goes bad?
Overall Basic Questions
1) I plan on using the boat 2 to 3 times a month, how much maintenance of oil and tune ups are needed at this rate?
2) Would you recommend replacing the On board Charger with one of the more current ones? 10 Years is a long time. I know that some can maintain the batter better when not in use....
3) Do I need to remove the Plug in the back of the boat after every use? Do bass tracker boats even have a plug that needs to be removed?? Sorry I know this is a very basic question, but I don't want to mess up being this is my first time owning a boat
4) What other problems if any should I be on the look out for?
Thank you all in advance, and I'm sorry in advance for asking such noob questions, but I know there is someone out there that has gone thru this just like me.....
Engine Questions
