las
- Sep 22, 2014
- 165
Hi from Denmark
I just bought an old Chrysler 65hp outboard and need some advice on parts and troubleshooting.
The guy I bought it from said that he could only get it going on the lower cylinder and that the upper was dry. He opened up into the reed valves and said that they where not closing, flipped the reed plates but no luck. He cleaned the carbs but nothing helped.
From what I can read on the forum the ignition seems to be troublesome on these engines and I find information hard to come by.
It says Magnapower II on the side of the engine, but the flywheel says Prestolite?
First thing I'm going to do is check the compresssion, just have to find a battery! And if it checks out ok I'm going to order some rebuild sets for the carbs, new spark plugs, a new diaphragm for the fuel pump and some new reed valves.
I managed to turn the engine with the plugs out, powered by my charger, and under no load both plugs fired. But I wouldn't know if they do under load.
But any advice on further testing and Things I should do would be welcome, and where to buy parts?
Regards
Lars
Regards
Lars
