JUST CHANGED THE STARTER AND SOLENOID.
robyroyboats31
I just changed the starter and solenoid on a 1977 115 Hp Evinrude motor and when I hooked the battery back up immediately the starter engaged the fly wheel. Do I have a wire crossed?
I just bought a new battery and I sure don't want to burn everything up I just bought. Any help would be appreciated? Have a blessed day.
mike_i
Ensign
It sure sounds like you crossed a cable somewhere. If you have a voltmeter, disconnect the cables and find the cable that has 12v only when the key switch is in the start position.
robyroyboats31
thanks, so much for the information, I don't know why I didn't tape them up instead of trying to remember, I have had a bad day all day.
Chris1956
Outboards tend to use the starter solenoid to connect multiple cables, as a convenience. You should have only one cable on each of the smaller solenoid terminals, (usually yellow/red and black) and only one cable on the starter cable terminal. The rest should be on the battery cable terminal.
robyroyboats31
Thanks so much, I moved some wires around today with no luck and even went by a Boat Mechanic Shop and everything he had was 15 years newer than what I had, my starter solenoid, which is on the boat is off a ford pickup and this is what I have always had and replaced with. The motor is 1977 model Evinrude 115
???-----Why would you even think of using a solenoid other than a factory one.----And I say that 9 out of 10 solenoids that are replaced are in good working order !
Chris1956
You will want to use a Johnnyrude solenoid. Automotive solenoids have an annoying habit of sparking, when energized. Not good under the hood of an OB with gas fumes everywhere.
robyroyboats31
Thanks for all the information found the wire that was crossed and I sure appreciate all the help, happy boating guys. Hope to see you on the lake.
