Just getting prepared to change engines have everything planned but the tilt/trim
iamwill1973
Changing out an engine the previous one a 60hp mariner has tilt/trim mounted on the transom mount. The new old engine has it's tilt/trim motor right inside the transom. Has anyone done this or will I have to drill holes above transom and design something to keep the motor out of the elements. Being it is a marine application can this motor just be screwed to the floor or what? For the record I am changing out a 1996 mariner 60 elpto with a 1966 mercury 650 on a 1996 mitch craft 516 center console. Please advise if you can.
iamwill1973
Re: Just getting prepared to change engines have everything planned but the tilt/trim
bump?
Texasmark
Tell you what. Post some pictures of the areas of concern to you and I guarantee you that we can come up with a solution.
Mark
Chris1956
Your new motor has the 4 hydraulic hoses that run from the trim cylinders to the trip pump/reservoir? if so, the holes for the hoses should be above waterline, usually on top of splashwell. There was a fitting to waterproof the hose entries to the hull.
iamwill1973
Sorry forgot about this post I sold the cc and bought a 15 ft glastron 1970 to put this engine on thanks for the help sorry.
