Just had my skeg repaired.. yikes!
Speedwagon
Apparently, my old '88 Alpha one has had it's skeg repaired in the past, and it wasn't done right. It was missing a bit of itself, and bent a bit, so I took it to a shop to get it fixed.<br /><br />$245 for them to cut off and re-weld the skeg. They apparently had to cut off the entire skeg, and redo the whole thing to make it right. I don't care much for those that go the cheap and incorrect route, when it costs me money later on. :) <br /><br />But hey, now my skeg won't be causing me to turn to the right anymore.
Twidget
Re: Just had my skeg repaired.. yikes!
$245?? Yikes! At least it is done correctly this time.
Speedwagon
Originally posted by Twidget:<br /> $245?? Yikes! At least it is done correctly this time.
Yea, that was my reaction too. But I just assume have it done right, and not deal with it anymore either. That, and it IS the only protection my prop has, so I'd rather give the prop it's protection. The two props cost me $80 and $75 too. So total bill for welding was $400!
Realgun
A skeg doesn'y protect the prop that much believe me. My wife fears the return trip cause almost every trip I take out the prop. :) So she got me a fish finder. Not to find the fish but know just how deep the water is. LOL :(
Speedwagon
How do the depth finders compare with the fish finders?
CN Spots
They're the same thing with different names.<br /><br />spots
Mike Robinson
Some depth finders are digital and only tell you the depth of water you are in. This style is commonly found on sailboats.<br /><br />A fish finder will have a display that will show objects between the bottom and transducer.
clemsonfor
the older flash lowrance flash qauge/finders can locate fish schools on open water if you know what signature to look for.<br /><br />-nate
