Just poured a NIDA CORE transom
Coho Ghost
If you are considering a "poured" transom core repair job, I think you will find the NIDA core product to be pretty user friendly, and I hope as time will tell, a very substantial repair.
Once my transom inner and outer skins were repaired, the easiest part was catalizing and mixing the NIDA compound. I was concerned that it would be "runny" enough to flow out into all of the core space, but it was no problem. The stuff is pretty runny before it kicks off. There is more than enough pot life time to get everything mixed and poured. I only had to pour 6 gallons, which was slightly complicated by having to work a 5 gallon and one gallon pails. I did the 5 first, power mixed it for a timed five minutes, then poured. I only needed .6 gals to finish the pour. In addition, the "calculator" on the NIDA web site hit the volume of compound I needed right on the button.
The compound is exothermic, which means it generates heat. After 2 hours the surface of the transom was running 150 to 160 degrees F. measured not estimated.
I did the whole job single handed without any hitches. If you were doing a bigger transom requiring 2 or 3 five gallon pails of compound, I'd recommend having someone help you.
Finally, the NIDA people have been great to work with. They have a tech support person, and their gal Ann Tromm has bent over backward for me. The compound is normally supplied in 5 gal. units, and one gal. units are only sporadically available on the tail end of a production run. Ann got the one gal. to me as soon as it was available.
I would post pics, but I couldn't mix, pour and take pics at the same time. If you have any question, I'll try and answer them.
Oh yes, and the cost of the compound was $132.00 for the 5 gals., the one gal. was free!!! The killer is the shipping; $88.00 to have the 5 gals. shipped from Florida up to WA. state.
Regards,
Coho Ghost
ondarvr
Re: Just poured a NIDA CORE transom
Always nice to get a report on a plan that worked out well.
Thanks
PS. now we need pics.
Marcq
What size boat/transom did you pour that product into ?
Thanks, Marc..
Coho Ghost
Marc,
The transom is 62" wide at the top, 14" down to the chine, and 20" in the dead center. The core space is 1.25". The boat is a 15' Livingston Pacific Skiff.
If you look on the NIDA web site, they have a diagram that you plug the dimensions of your transom into, and it gives you the needed volume of compound.
Coho Ghost
Bob_VT
I can't believe you forgot the MOST essential item :eek:
The camera! Where are the pictures!! ;)
jspano
Bob_VT
yes, what he said!!!!!!!!!!!!
pic please, even if it's the finished product!!!
chrismarion
According to the calculator on their site it would take 14 gallons (2.85 pails) to do my transom, $376. 6 gallons for $292 for SeaCast. I wish I could afford to do that in my build. I would love to do stringers and transom.
Bob_VT
THAT is the primary rea$on people go the traditional route with wood and resin :)
Coho Ghost
If one of you fine gentlemen would explain how to post pics, I will put on what I had done on this project.
Thanks,
Coho Ghost
redfury
Well, first you need to decide how you want to manage pics online. I prefer Picasaweb, using Picasa from Google. I can sort through my pictures on my computer, pick the ones I want to upload, and then batch upload them to my Picasaweb page and then open the ones I want, right click, hit properties and snag the link to the picture. Then I post the link here using the image tags
COLOR]
and Wala! You have a picture posted at Iboats for all of us to peruse.
Keep your pics in the 800x600 format whenever possible, but Picasa has never given me any problems like blowing out frames even when I upload high MP images...it adjusts the size for web viewing automatically. If you want to see the high rez pic, then you can go to your Picasaweb page and hit the magnifying glass to see the picture in its native format.
jonesg
seacast is $200 a pail ++
3 pails is $600 plus shipping, $700++
Nida is half the cost of seacast. ( wish I used nida but...)
