Re: JW - 10 carb./cam setting.
On the cam there are 2 screws, loosen them. (Look underneath armature plate)
Now there should be embossings(dots) on the tank bracket. Move the speed control lever to position between those two embossings. I believe the handle will be over the SLOW marking on the tank bracket. Looking down, the left side of the speed control lever over the "L" in SLOW and the right side of the speed control lever over the "W" in SLOW. You should see the dots anyways.
There is a stamped line on the top of the control cam. Move the free end of the cam out until it makes contact with the cam follower at the index mark.
Now tighten the cam screws.
All done!
