kasi
Carmelo
Hello I have a Yamaha 140 H/P v4 Year of make is 1995 I suppose I`m not sur about it.I bought it recently. It works good on idling , on giving the gear it works good on slow moving, but when increasing the speed, it slows and wont speed up. I inserted a new spark plugs. To say the truth I have the inlet of the fuel D/F filter. is broken, but I am not supposing that there`s a lack of petrol flow, I am supposing that there might be some dirt in the jet, but these were clean before.I even sprayed some calburator cleaner but it did not work out.
bowhuntrrl
Re: kasi
Spray carb cleaner will not work !! You will have to take the carbs apart for a proper cleaning. Be sure to take all jets out and clean all passages. Then set adjustments to factory specifications. You will probably need to buy a repair manual.
Carmelo
Re: kasi
Thanks that was a great idea I done as it was suggested and it runs good, but now I have another difficulty, I don`t have a manual book so I have to ask, to set the cal for economic consumption, am I suppose to open the adjusting screws two and a half turns, or I have to test it with some kind of equipment. In my opinion it seems to be running very rich in fuel cons.
