Hi all,
I have a OMC 5.7 with a 1.5:1 Cobra drive.
The boat came (when I bought it) with a 15.5 X 15P alum prop. The prop looked pretty dinged up so I planned on getting a new one but first I put the line on the hub and prop to see if the hub is spinning at all. It was. I didnt have any symptoms like slipping and letting go and high revs or anything but I took the prop and got it reconditioned and rehubbed and changed to a 17P.
I also bought a 14 3/4 X 17P Ballistic SS prop. I bought it from a marine surplus store and long story short I could t get it to go on because the hub wasnt pushed in enough. I had to take it to a prop shop and they put a new hub in it. I put it on the boat and about 5 hours of run time later it let go while underway at about 3500 RPM. I had to idle all the way back to the dock.
So then I took it back to the prop shop and they said they would rehub it for free but if it does it again its prob a problem with the hub cavity of the prop.
So I just put the alum back on and put about another 20 hours on it. I bought an apollo SS prop so I took the alum off and looked on the back of it and I can see the hub must be spinning again. Again I have no symptoms like before but I can tell its spun.
So, so far I have spun a 15.5 X 15P alum, 15.5 X 17P alum, and a 14 3/4 X 17P Ballistic SS.
I havent taken the boat out with the new Apollo yet but I plan to this weekend. the Apollo has the interchangeable hub so maybe it wont spin.
Is there anything that would cause this or am I just having bad luck with props?
Thanks
Thanks
