Re: keeping boat on a slip
OK guys, I am thinking about putting my boat on a slip next season and am trying to weigh the pros and cons. I have already talked with the marina and know I can bring my own gas so I don't have to pay the extra dollar per gallon for gas. I already have a wagon I can use to transport gear to and from the boat and have a good cover. The boat will be at a lake that is an hour away so I would save the extra gas towing and extra wear on tow vehicle. I feel that I would use the boat more because I could go out alone and would only have to deal with launching and retrieving once a year.
Do need bottom paint?
Can any of you that have slips give me some of the down sides or positives I may not be aware of?
If it's all about the cost don't do it. It cost less to put it in and out then leave it in for smaller boats. If it is for pleasure and enjoyment go for it. I have two slips and love it, one for the boat and one for the seadoo.
No need to bottom paint a pontoon but as others have mentioned it will take some work to clean the crud off the pontoons every year. If you do put ablative bottom paint just to the water line this will be a easy clean up. No need for barrier coat prior to bottom paint but will need a good cleaning and correct primer. I like Interlux
Micron CSC in shark white because I am in fresh water. Easy clean and is designed for a boat which can be hauled and re-launched without repainting. If your not talking about a pontoon as in you pic then you will need to have 3-coats of barrier coat before bottom paint.
Being in Jeff, IN I take it you may boat in the river which build up will be more.
A note on gas, the Corps of Engineers does not allow gas to be transported across any dock and this is not to say that it is not done all the time. Most folks that do it never have an incident but as they say, stuff happens. Just FYI
