OK, I traced the wires. One purple wire from run position on key switch joins with another purple wire that goes to + side of coil and both wires connect to one end of resister. The other side of resister goes to alternator. When I unplug wire from alternator the engine cuts off with key switch. When I plugged the alternator wire back on the resister the engine keeps running when key is turned off. Makes no since to me. As stated above, the resister properties test good. It seems something is wrong with this wiring configuration. In present state, wouldn’t the coil have constant voltage from wire on key switch?
