Kick back when you try to start it
mr comfy
Hey guys i just tried to start my motor after a month or two and it did fire but then i got the biggest kick back ever!!!!
Now when i try to pull the rope within two or three pulls it kicks back really hard.
My mate said the timing might be out????
If anyone knows the workings of a johnson 25 sea horse could you give me a yell as it runs great but i am not game to try and start it now. It is like an explosion and it hurts when it bucks.
w2much
Re: Kick back when you try to start it
Plug wires crossed.Switch them.
mr comfy
thats the problem i havent even opened the motor case so it cant be the plug wires?:confused: It is the same as it always is.
AlTn
the other quick check is to check your flywheel key....sounds like it may have sheared and allowed your flywheel to slip on the shaft,which will put your engine out of time
JB
I vote for the flywheel key sheared or the stator severely shifted.
If the plug wires were switched it would make loud explosions from the exhaust.
mr comfy
Flywheel key? Ok is that a white plastic thing that goes on top of the motor and stops it spinning back? If it is that is the problem....
I found half of it at the bottom of the caseing. Will i have to get the timing done as well?
JB
No, the flywheel key is steel and holds the flywheel in time with the crankshaft.
You really need an OEM Service Manual. It is not cheap, but will pay for itself many times over.
www.outboardbooks.com
mr comfy
I cant afford to buy a new oem service manual but i just need to know where the fly wheel key is?
I have attatched a diagram so please tell me which part to look for.
Thanx guys
Oh yeh it is a 77 seahorse 25hp lol
JB
Wrong diagram. Find the one that includes the crankshaft.
bktheking
Thanx guys
0307480 KEY,Crankshaft
You need to remove the nut holding the flywheel onto the crankshaft and get yourself a puller and pull the flywheel, the key (or at least the half stuck in the crank) will need to be removed.
