KICKER MOTOR MOUNTING
copalope
I have an '84 18' Searay Seville. Just pickedup a kicker motor and new Fulton bracket, but the aft is not flat where I need to mount it for engine to raise properly. Wondering if there is a bracket on market I can buy that I can mount to boat, then mount the kicker bracket to that. Any ideas?<br /><br />greg
Bob_VT
Re: KICKER MOTOR MOUNTING
Kicker brackets are normally designed for the transom angle. You might have to have some aluminum wedges added to attain the proper angle or there are adjustable brackets on the market.<br /><br />Bob
copalope
It's not the angle I'm worried about so much. A small wedge would fix that. My problem is the design of the aft. It almost comes to a slight point RIGHT where I need to mount the bracket. Below it and I can't get the motor out of the water. And above it is too high... plus the angle is way too extreme.<br /><br />greg
