I'm using my early 70's Evinrude 9.5 for a kicker on my walleye boat. I believe I currently am running a 7 1/4" prop (pin drive, not thru hub exhaust). I would like to find a prop that will drive the boat at a good trolling speed (2.5 mph) without excessive engine RPM. My current prop makes me run the motor a bit more than I think I should have to. Would going with more pitch and diameter make any difference?? I was thinking of going to an 8 1/4" 8 pitch or similar. It has the factory prop which is in OK shape, but itis an old design that has no cup to the blades. Any input is appreciated. Thanks
