KICKER QUESTION
JESBALLS
HI GUYS IVE BIN THINKING ABOUT PUTTING A KICKER ON MY BOAT .MY QUESTION IS IF MY MAIN OUTBOARD IS A LONG SHAFT DOES THE KICKER ALSO HAVE TO BE LONG SHAFT OR CAN I PUT A SHORT SHAFT ONE ON MY BOAT?
mellowyellow
Re: KICKER QUESTION
no need to shout dude...(all caps.)<br />if u get an adjustable bracket, no worries :D <br />unless u have a HUGE transom :eek: <br />good luck trollin'<br />M.Y.
tmcalavy
Re: KICKER QUESTION
I have a Merc 500 50 hp on a 20-inch transom, and I routinely use short shaft (15 inch) kickers ranging from 4 to 10 hp for trolling and as a backup. You'll go faster if you can get the cavitation plate down even with or just below the hull, but no worries if you can't. You just won't putt-putt-putt along as fast, that's all.
Boatist
Re: KICKER QUESTION
Jesballs<br />I do not know the size of your boat or where you boat, but I would go with the long shaft. If you do any ocean boating or area with big swell it is a must. Short shaft in ocean often has two problems, Power head goes completely under water and then the prop comes out of the water with a following sea. Inland flat water the short should work ok.
