Lion hunter
- Apr 9, 2005
- 1,529
Trying to add a 9.5 johnson short shaft kicker to my boat. It already has a transom jack on the boat. The problem I'm having is because it's a short shaft I have to let the transom jack down with places the back of the kicker leg about 5-6" behind the main motor leg. I assume that when set up the steering link should be paralell with the back of the boat when both motors are straight, is this correct. If so I am guessing that I need to attach the link to the rear of the leg and extended it back on the main motor 5-6 inches to make it parralel. I tried hooking a link right to the rear of each motor and I lost full steering on the main one. I need to go back to HS for geometry lessons.
