kill switch
popee1950
I have a 1985 xr2 that i'm putting back on my boat after being off for about a year. I forgot where to kill switch wire hooks to the motor. Could someone help me out as to where it goes. Diagram would be helpful. Thanks Lee
17rogue70
Re: kill switch
what kill switch do you have ? i just went through the same situation myself with an 89 xr2. i used an aftermarket switch. depending on the switch. you have to use the black wire with the yellow stripe and a common ground. with a little more info , ican help in more detail.
popee1950
Re: kill switch
It's just an after market switch. Had it hooked up and running a year back,just can't remember where to hook it on the motor.Had the motor off doing restoration work. Thanks for the reply
oldman570
Re: kill switch
Wireing diagrams for your motor can be found at "1manual.com/mercury". There you can find what you will need.
Oldman570
