knock sensor, brass Y-fitting for both the sensor and drain plug Cant find a part number
JohnEG
The knock sensor has a brass Y-fitting for both the sensor and drain plug
I need the Brass Y adapter
I Can't find it or a part number.
not sure if it's a Mercruiser part.
1998 5.7
Thanks
Scott06
Man that is salty for what amounts to a 1/4" npt wye. You could order stainless pipe fittings from a place like mcmaster carr for a few bucks less
JohnEG
The Knock Sensor has a different Thread ( fine) that blue drain plug.
its $95 i think ill get a plug and take it out of the block and try to EZ out the rest of the knock sensor The boat is in the water so it adds a little stress to the work...
Scott06
gotcha sorry for the confusion.
Bt Doctur
They make a 1/4 inch pipe "T" , works just fine, found mine on ebay
