Knocking sound - what is it? [video]
morebacon
Hey folks, I started getting this weird knocking sound last time I went out. Thought it's valve clatter so I did an adjustment (#1 was just slightly loose, but not by much). That didn't fix it unfortunately. Any suggestions what I should be checking next?
Mercruiser 3.0 Knocking Sound
I'm currently rebuilding the carb, changing the oil, spark plugs, etc. but that is part of the regular maintenance I was planning regardless. Thanks.
Here are two videos (front and back of the engine). It's much louder when facing the engine.
dubs283
I don't know if it's the video frame resolution or me but the power steering belt appears to be loose. And the pump itself seems to be moving?
dubs283
Didn't see the second video initially. Agree with exhaust leak sound
Will say if the engine is warm during the video it is running pretty rough, even for a 3.0 L
morebacon
Good eye! It was indeed a bit loose, but the frame rate makes it look much worse :)
morebacon
Agree! It was cold, but running too rough compared to last season - that's one of the reasons for the carb rebuild.
morebacon
Hi folks, Thanks for the suggestions - just wanted to give an update that it was indeed an exhaust leak, the exhaust manifold gasket was blown.
Looks like the gasket itself was not the right fit, could this have been the reason?
Also, I remember reading somewhere that these green gaskets are not that great and should be avoided, in favor of the aluminum layered ones. Is that right?
04fxdwgi25
Who ever put that gasket on should be taken to the wood shed and beaten. Or at least have his / her tools taken away.
No paper gaskets on exhaust.
No gaskets that cover the exhaust ports on engine.
Wrong gasket.
Scott06
Two different styles of head ports and corresponding intakes were used on 3.0 s nit sure the transition year.
would make sure you have match head and manifold and get correct gasket
morebacon
I'm confused by this - got the gasket based on the engine serial, but seems the ports are still a bit smaller too. I'm worried because the previous gasket melted exactly at those ports that were covered:
Here's how my manifold looks:
Looks like this new gasket is what comes in the kit as well - is it OK for the ports to be smaller?
I also found this adapter plate, but looks like it's for pre-1990 manifolds:
So is it OK to install the gasket that I have, with the smaller ports?
ScottinAZ
Master Chief Petty Officer
I wouldnt install that gasket. Not only are you losing power due to restricting the exhaust ports, but you will likely blow the new one in short order as well. May take a bit of research to find the right gasket, but that is what needs to be done. A previous owner may have changed manifolds to the large port piece. IIRC my 1980 vintage 2.5 has the large ports, and when I changed the manifold, the gasket called for was the correct large port one
Scott06
I wouldn’t install that gasket with those ports. Would think someone swapped the head or manifold.
Maybe merc tech support can offer a solution or just order the earlier style gasket and see how it matches up
I believe the Barr kit is you can mix and match earlier and later manifolds and heads
