Captain_CGC
- Aug 6, 2012
- 27
Greetings
In August last year I posted a topic on the Kohler generator on my boat (2008 Four Winns 288) that was not starting via the remote switch. After several months of trying to figure it out, I finally resolved the problem. I decided to share the solution in order to assist others in addressing similar situations. It's a Kohler 5ECD Generator
At first I suspected the remote switch had failed. I removed it and tested it, it was fine, however I inadvertently damaged it and needed to find a suitable replacement. I acquired a standard (on) off (on) switch online, installed it and the system still did not work. I suspected that I had done something wrong and studied the wiring diagrams for the boat. The manual I have for my Four Winns 288, does not have the wiring diagram for the generator. I contacted Four Winns and they sent me the appropriate drawings. I also studied the wiring diagram for the generator and tested all related components. I removed and tested the Advanced Digital Controller on the generator, no damage.
I was at a loss, then I decided to find the wires that go to the cabin for the remote start and now things became interesting. The plug is on the stern side of the generator and almost impossible to reach. The plug is under the seawater pump for the generator and while I was sandwiched between the engine, the generator and the floor in great pain, because the coolant cap of the generator was squeezing into my chest. I felt water under the seawater pump, on visual inspection (another contortionist trick required) I noticed water dripping from the pump. This water drips onto the plug that connects the generator to the boat systems (12V). The plug was completely corroded, the root cause of the remote start problem, was the faulty seawater pump. Why the engineers/designers decided to place this plug as well as the 12V positive and negative terminals underneath the seawater pump is beyond me. Surely they must know that those pumps occasionally fail and that water on any electrical system is undesirable.
The solution: It took 2.5 hours to unplug the corroded plug, this is due to the difficulty in reaching the plug and depressing the locks and pulling on the plug simultaneously with one hand; with a coolant cap buried in my chest and a Volvo Exhaust crushing my head. Then it took another 3 hours to remove the female section of the corroded plug from below the seawater pump to a more sensible location, above the generator. This was a very painful exercise, so much so, that half way through the ordeal, I was ready to give up and devise a plan that would require the removal of the starboard engine to get access to the faulty plug. I know that sounds crazy, but I like everything on my boat to work 100%, every single switch and lightbulb must work. I eventually used a flashlight, mirror and a utility knife to cut off the top clip that prevents the female end of the plug from falling out of the plate into which it is mounted. It is impossible to reach the lower clip without removing the starboard engine. With patience and mild torture, I was eventually was able to remove the plug.
Note: I had to remove the seawater pump before I could get access to the plug.
When I was finally done after a total of 7 hours, I had to figure out the wiring and rewire the plug. This was a fairly simple task.
I acquired the spares to service the seawater pump, 3 hours of coolant cap in chest, cuts and bruises, the system was ready. I installed the new rocker ((on)-off(on)) switch in the cabin and finally after more than 18 months of research, frustration and hard work, I resolved a simple problem with a painful solution.
Why do I post this?
I hope helps someone with a similar problem.
I advise those of you with a similar set-up in your boat to go and inspect it and make sure that the seawater pump is not leaking onto this plug.
I suggest if you don't have problems now, with a similar set-up, try and move the plug before it corrodes and becomes very hard to work with.
Inspect the seawater pump regularly. It is pretty well hidden and really hard to inspect, but it needs to be done.
Be warned, there is very little space to position yourself to do this work, and your legs, chest and arms take a beating in the process.
I hope this helps someone.
Regards
CGC
Why do I post this?
Regards
CGC
