BaylinerBluez
- Aug 18, 2016
- 4
I have a Force L-drive 120 hp I recently purchased and was able to get out on water for about 3 hours until it started giving issues. Originally the issue was when giving it throttle the engine would bog down then die, but now I'm not getting any spark at any of the cylinders. I tested the stator and it was bad so I replaced that, thinking it was the only issue but that is not the case. I have checked the trigger, regulator/rectifier, and stator and all check out ok except when cranking over the stator is only putting out about 85 volts. Thanks in advance for any ideas or solutions.
