ttownthomas
- Jun 7, 2019
- 199
I'm planning a complete re-wire on my 25 Bertram. It has Twin Mercruiser L6's and Ill be clean sheeting the electrical system since all wiring has been removed from the boat. the original harnesses have a 6-ish gauge power wire that ran to an ammeter for each engine and then the house loads and their fuse blocks tied into this larger wire. Thus the house loads were generally split between the 2 batteries. In my case I plan to have a dedicated house battery and thus I will not need this larger wire to run to the panel. I would like to eliminate it and probably will build my own harness. Re-writing/drawing helps me learn so I have re-drawn the wiring diagram (with some slight modifications) from the FSM but was hoping the forum could look to see what I am missing on this diagram.
What type of battery switches will I want with 3 batteries? Where should circuit breakers go? Should I run the trim pumps off the starting batteries?
