Labels for Instrument Panel
64osby
A few years back there was a thread I saw where a guy printed his own. Have to find the right "stock" to print on.
wellcraft-classic210
Master Chief Petty Officer
I use a Ksun label maker for lots of things like that and also to wire labels. Brother makes some lower cost units that might be suitable. I you just need a few send me a pm and I may be able to mail you some for free.
redlinj
If you want to go high tech, go to a trophy shop and get some engraved. I'm sure they will cost more but they will sure look good!
Fleetwin
Will do. Thanks
gm280
Fleetwin, You are in luck. I have actually done that exact thing you are talking about for my tri-hull Tom Boy boat panels. The only limiting factor is your own mine. Colors, textures, patterns, text, fonts are all easy to do. You can make a totally new panel with all those things etched in it, or merely have some labels made to stick on your existing panel. But once you see what is available, you will have tons more ideas for you needs I'm sure.
My wife use to run a Skills shop that made trophies and panels and you name it. She was in charge and ran the LASER section. And since she retired, we bought a large bed LASER system to make such panels. NO, we don't make things for others....sorry! But I stated that to show you how it can be done and where to get it done locally at your community.
Here is my design for my Helm Switch Panel. This a computer rendered design to get the basic layout.
This is the cutout pattern for the LASER to use.
And this is the finished Helm Switch Panel.
I shown you this so you will think of the possibilities and see what can be done in your community. This is merely done using a LASER etching system that every trophy shop have. So make a simple design of what you want, take the design to the trophy shop and they can LASER it out on any color panel you like with any pattern, color, texture, font, lettering color, shape you can imagine.
Here is another one;
There is no limit to what you could do. And since the lettering is LASER engraved into the panel, it will never wipe off either. My panels were done on a brushed aluminum looking panel with black lettering and lines. JMHO!
I will be redoing my dash later this spring, however my dash is a z-formed piece of aluminum. so sending the current dash to the laser guys (or doing it on the work laser) is out of the question unless I redo my dash from scratch. The lettering and the dash graphics have long since faded or been rubbed away
my three current lettering/graphics paths are as follows:
  • water transfer decals with a clear paint overcoat - many decal shops will make water transfer decals for very little money, and there is water transfer decal stock you can get for both a laser printer and an ink-jet printer
  • vinyl (scotchcal) decal for the whole dash with a 10 mil velvet lexan overlay, not that expensive, will last a while, however not the look I am going for.
  • have my buddy pinstripe the dash and fine-line the lettering.
Im leaning toward either the water transfer decals or the pinstripe
Woodonglass
I've used the water slide decals, and they word really well. Laser printer then a couple of light coats of Rustoleum Clear Acrylic. You can slide em off and into place with ease. Once dry 2-3 more coats of the clear acrylic and they look great.;)
Here's one I did for one of my Adirondack Lawn Chairs...
gm280
Scott, I do like the water slide decals as well. But if you have plans to clear coat over them after the fact, make sure the aluminum is prepped to take the clear coat. Some times metal does goofy things when clear coated. So just prep the metal before installing the decal and it should look great. I do clear coat a lot of things. And have noticed bare metal can be iffy with clear coatings some times. JMHO!
my dash was originally powder coated. will be painting it an anthracite metalic, or a medium silver metalic.
agreed, bare metal and clear do not mix well. (no pigment and binders to hold the paint together)
Woodonglass
Another option would be to us Large Clear Mailing Labels. I did that on my Old Evinrude Outboard and it worked good I clear coated over that too.
fhhuber
Draw up your dash plan CAREFULLY and take it in to a trophy shop... They can etch all the lettering into brass plates or plastic or whatever... you drill the gauge holes.
Has anyone had experience with backlit panels -- I am thinking that a coated plexiglass with laser engraving might be a good way to go.
I have some in a 1983 searay done in that fashion -- has a brushed aluminum look & backlit /// probably not laser engraved on those days // They work great but i would like to add a few features some day.
gm280
Another option could be to have a silk screen made up for the dash and use that to re-label everything. Just a suggestion. :noidea:
boatman37
i have a small CNC machine in my garage. if i can find a source for the right material (i haven't even looked) i could make some pretty nice stuff. i have thought about trying to make a few things for the boat but haven't yet. i have etched glass and steel and it turned out really nice using a diamond drag bit. but most of my work has been with wood, mainly signs
DeepBlue2010
What are you asking for is a product already on the market made by a company called BlueSea here in WA. Just google blue sea labels
They already made so many labels sizes and they have a custom order form on their site to design your own. If all you need is a label you stick on the panel, check them out.BlueSea Lable.jpg
gm280
There are tons of ideas. All one has to do is search for them. Most anything you can imagine is doable these days. And honestly, the cost isn't as bad as most would think either. Computer technology makes it doable and affordable. JMHO!
