Peaceful Pirate
- Aug 26, 2007
- 71
We have an older M/C 140hp (mid ?70?s) that is now in a deck boat and has always run just fine; even to the point of being able to jerk our 19 yr/old our of the water on skis. Then this past week it developed some rather odd problems that have us a bit stumped on how to best approach a solution.
Normally when giving it throttle, the engine comes up to WOT of about 3500 RPM in a smooth and steady run-up. However, this past week, when giving it power, the tachometer would run way past the normal 3500, and max out on the tach to 6000; but by engine tone and sound, you can tell it is only running in the 2000-3000 RPM range. At the same time, when you reach about half throttle, the engine begins to cough and lug like it is being fuel starved. Power out put appears to be less than half of normal WOT.
When the throttle is backed off just a bit, the engine settles down and runs along at about a third to maybe half speed/power, but the tach is showing it running at around 5000-5500 rpm; with the occasional engine cough and/or lug.
We had a Pentronix ignition conversion in the distributor, so we pulled it, put the old point system back in, but doing so made no change in the problems.
The power loss and cough and lug brought the accelerator in the carb to mind, but that would not account for the tach RPM run-up. The tach RPM run-up brought up maybe coil (a ballast system) or maybe distributor problems, and even a possible alternator problem.
So rather continue on chasing our tails and just replacing parts for the sake of replacing them, it is time to sit back and reconsider our approach. We would appreciate any thoughts and/or recommendations anyone might care to offer.
