5.7l OMC Cobra (1989)<br /><br />Motor has always performed great until this happened. After cruising for an hour, shifted to neutral and motor stalled....no way to start it up. <br />So, I suspected the coil was the problem, since the next day (with a cold motor), it did start up. I proceeded to change coil, distributor cap, rotor, condensor. The timing, the gaps on points, everything is right on spec. Ohh, and the fuel filter is new since beginning of the season, and carb (4bbl) is in good condition.<br />Anyways, the engine started up GREAT with the work i did on it. Idles and purrs like a kitten. I can rev up the motor on neutral...sounds perfect.<br />Then i take it on the water for a test run...at low speed, runs perfect...but when i push the throttle down.....lack of power..the boat cant get planing like it used to.
<br />Checked the fuel pressure at the carb...looked ok to me...so pump isnt the problem.<br />Any ideas on what else i should look for ?? Really strange that this problem happens just after doing some ignition work...hmmm
