lack of speed
dabears1
i have a 1973 70hp evinrude. i cleaned the carbs this winter,because it would stall when i put it in foward. that fixed that problem,but now it will not reach a speed over 10mphs. could i of missed something cleaning the carbs or do you think i have another problem?
boatradioman
Re: lack of speed
I think there is another problem.get your boat checked.
HighTrim
Re: lack of speed
Possible your jets are clogged, or could be dropping a cylinder.
Check the spark and compression, post your findings.
tashasdaddy
Re: lack of speed
look at the sticky top of this subject, did you do all of what it says.
kskomro
Re: lack of speed
I have the same problem. I found my top cylinder not fireing. put in new plugs, run them for a short period, checked them, See which one is not fireing. Then swaped coils and see if it follows. That is what a few people here has told me to try. Now it's at a repair shop, and when I told them of the various things i've tried at least they did tell me I saved them alot of time, thus saved myself money.
