Land and sea prop
Trytten
Just got a torque shift prop 932 can't get it to shift its on my 20 foot I/o with a 305 merc I'm runnin w cams and 30 lb springs which the prop came with the hole shot is crazy but won't shift up played with the trim does not make a differance any help would be great thanks
steelespike
Re: Land and sea prop
Someone on here has some props and parts Don't know if they are still around but maybe someone remembers who or may have some tips.I've seen the video demonstration , boat just about leaps out of the water shifts up and flies.
Trytten
I seen the same video on u tube after I got the prop. The prop was just given to me so I thought I would tinker with it just came across some 15 pound springs and some x cams gonna give it a try tomorrow if the weather is nice.
Trytten
Ok so Got the new prop to shift finally but I have to use tons of trim and cant give the boat anymore then half throttle or it will bounce off the rev limiter thinking I need a different set of cams so it will shift faster. Kinda driving me nuts been on the water for 3 hours setting pitch changing springs and cams. Anyone out there got any suggestions.
jestor68
Those props are trouble. They work properly for a short while, then start screwing up. They require constant adjusting to keep'em working. They are more trouble than they're worth.
It was an experiment that didn't turn out well. Maybe that's why they're out of business?
The video demo was performed after much fiddling and adjusting to get it to finally work right long enough to make the video.
PS94
From the linked website:
NOTICE: we have discovered that the factory that made our last cams mislabeled the X with the ZZ. If your boat revs rapidly then cavitates, it probably has the mislabeled ZZ cams and should have the correct ZZs. If the boat bogs and doesn't take right off, it may have the mislabeled X cams. Email me for availability. It will take 3-4 weeks. If you can remove the cams, send them to me and I'll send the correct ones ASAP. Bob M.
