Larson lxi 208 - Gauges Quit
Terry Freeburn
The Tach, Speed and Trim gauges stopped working.They light up with the rest of he gauges. I have always had problems with the Trim gauge working on and off since i bought the boat in 2005-6 new. It has a Volvo engine. anyone know where to start looking
bruceb58
Check your grounds. They are typically daisy chained which would explain why all went out. The power is also daisy chained so check that as well. Not likely going to be a fuse since power comes from the ignition switch and is not fused between the ignition switch and the gauges.
89retta
Also noticed your speedo stopped too. The speedo should run off a pick up tube so it should still work. Or are you asking about the lights in the gauges?
