I'm having some trouble getting this 90hp johnson(J90TLEOR) to fire up. The only way I can get it to start is to spray some premix in the carbs. I thought it was the leaking primer solenoid lever so i replaced it. No luck. The fuel is coming from a clean small tank. Everything seems to be fine all the way to the carbs. The primer is getting fuel into the carbs. I have drained them 3 times now just to make sure. Im kind of unsure on the process from there. After I spray the premix in it will idle fine and run normal. I can restart it no problem for hours. Next day its back to spraying the premix. I guess I'm just looking for some ideas on what I can check next. Any suggestions would be greatly appriciated. Thanks guys.
