late 70's 3 cyl 70 hp E-rude
randy4140
Hello; I am looking at a 70 hp Evinrude 3 cyl. say to run but "not in a couple years"
Probably needs carbd cleaned ect, no big deal. Is there anything else I should look for?
Is this an electric shift motor? I heard that could be bad?
Thx for any replies;
Randy
Carpfisher
Re: late 70's 3 cyl 70 hp E-rude
Compression and water in the lower unit oil check. Get it for REAL cheap if you can't sea trial it on a boat. If you can get it running on muffs, do a cyl power drop test- making sure all 3 cylinders are pulling there weight.
ezmobee
1972 was the last year of electric shift. If compression is good, everything else is fixable.
classiccat
"Captain" + Starmada Splash Of The Year 2020
Good Luck with it! These engines seem to be held in high regard and I'm already finding out why!
I just picked-up a 1975 3cyl 70hp (in fact, I'm still on the road with it!)
the good news: Even compression on all 3 cyl...all within 1-2psi...pretty amazing considering the fact that that the water pump wasn't changed in 20 years! If that impeller is still intact when I drop the LU; it needs to be entered into some sort of Hall of Fame!
I don't know if water intrusion / seal issues are systematic (i couldn't get the unit to go above 8psi in a pressure test).
the only issue that I see on the powerhead so far is 3 cracked coils and 2 rusty head bolts.
Net: I'm in for the following: LU reseal kit, waterpump kit, 3 carb kits, fuel pump kit and 3 coils...and I'm still stoked about this engine!
BonairII
Good compression is key. The coils are like $30 bucks each. I love my motor(see my sig)....it runs like a top, and sips gas.
bonz_d
I've got a 1988 70hp that came on a project boat. Right now the driveshaft is frozen into the crank and the exhaust housing is cracked from them trying to remove it which is the way I got and as soon as I can find a donor it will be getting repaired and hopefully used.
