Hello all.
My 1997 Larson Cabrio 310 has a wet bar with a hatch lid. There is a small piston that is used to keep the lid open. The piston on mine went bad and I end up losing it about a year ago. To others that one a 300 or a 310, can you tell me the length of this piston when extended and the number of pounds it should support (I know a 10lb piston is not strong enough).
Oh... and for those with the same model... do you actually use the "wet bar" at all? It's basically a sink with a cold water faucet. I'm thinking of hooking up this sink to one of those aqua fina 5 gallon jugs you can buy as I don't drink the tap water out of the boat. Just a personal quirk I guess.
Thanks,
--Rick
Thanks,
--Rick
