laying fiberglass (sticky situation)
pete44
I am a novice on laying out fiberglass/wood floor ...Redoing floor in bow area of my bowrider and had a heck of a time laying fiberglass cloth/mat down...I wanted it to be really secure so I am trying to lay cloth/mat and resin on top and bottom of repair seams of floor..I did top with no problem.... wet down board first with resin then laid cloth/mat on top..smoothed out resin on cloth until cloth appeared "clear"..added a couple of more wider layers on top of it repeating above steps...My problem was I wanted a real good re-inforcement on BOTTOM of new to old floor connection as well..Fiberglass cloth/mat stuck to everything but the board.(gravity is tough). :mad: ,,,Is it REALLY necessary to do bottom of board?Thanks,Pete44
Laddies
Banned
Re: laying fiberglass (sticky situation)
Try covering the patch with wax paper held in place with tape
ED21
Master Chief Petty Officer
Overhead is always tough.<br />Try letting the wet down board set up until tacky.<br />Then roll on cloth & let it setup a little more, then wet out w/ a roller.<br />Use staples to tempararily hold in place if needed.<br />Be prepared to get sticky. ;)
prockvoan
Staples,use S/S,can get them at any Home Depot.
