I just purchased a Lazer II prop, 25 pitch off of ebay.... Mounted it on the motor last night and it fits perfectly... However, I noticed that this prop's outer hub diameter is around 4.5" at the front, which is about 1/2" larger in diameter than my 4-blade Trophy prop. It's not larger than the gear case but getting close to matching it. <br />So my question is, is this Lazer 48-16550A45-25P, spec'd for use on my engine, or is more suited for 200hp and up...<br />I'm just looking for 200 less rpms and some more speed, but I'm wondering if this diameter increase may cause even more rpm loss. <br />I'm going to try it to confirm, but wanted your opinion...
