SwampThing
- Nov 6, 2006
- 117
Did a search and didn't come up with any discussions on lead fuel additives.
I'm sure you've had to of had this one before.
I'm curious about the use / need for lead fuel additives for mid 80's engines and prior. The lead in leaded gasolines was originally used for valve seat lubrication. So my question is; are lead additive necessary or should I be adding it to my fuel mixtures?
I have 3 older outboards - a 1986 125hp Force which says it can use leaded or unleaded fuel. And a 1961 Johnson 75hp and a Ted Williams 4.5 hp from the 70's. Not sure of exact year, guess I should double check it.
I wondering if I should be using the lead additive. Is it "Needed"? Am I doing harm to the motors by using it or would I be doing harm to the motors by not using it. The Force literature is the only place where I've found any mention of lead verses unleaded fuels. But it only states that leaded should be my first option unless it's unavailable.
Is there a definitive answer on this topic?
