Leak, can't find
damielke
I have a small leak in one of the tubes. I have replaced the valves. I have used the water and soap trick and cannot find it after hours of searching. It will hold air for about 2 days. Has any body ever tried the smoke in a can test? I am sure it is an easy fix once I fid it. Any suggestions is GREATLY APPRECIATED!!!
airshot
Add more liquid soap into the water to get it thicker, most folks use to little soap and don't see the bubbles. With enough soap, a tiny hole will make really big bubbles!! You will need to overinflate it to make bubbles!
damielke
Thank you so much! I will try that.
909
Do what Airshot mentioned and make the soap mix more concentrated.
What I do is use an empty bathroom foamer bottle, make a strong mix, and it will literally shoot froth . Coat the entire boat in foam until it's all white, then use your hand to move it around until you see new bubbles forming.
airshot
Yes...I have had better sucess with using my hands to move the soap around, rather than using a brush.
