Capt Frank
- May 21, 2010
- 2
Bought a 2003 19.8 Carolina Skiff with Yamaha 90 four Stroke . Took it to the dealer for compression check and to have the carbs cleaned because the motor was not running right. Mechanic tells me the compression was fine except for one cylinder which they thought might be carbon build up. Get a call and they are telling me that the head needs to be pulled because after the carbs were cleaned the motor is backfiring thru the carb no 1 and they checked the timing which was all right.. They then did leak down test and said one of the cylinders is losing compression. I don?t understand the ?leak down test? Could backfiring be caused by loss of compression or could it still be a carburetor problem. Any help would be appreciated
