I've just discovered that while cruising in my recently restored 1962 14' Starcraft, that water is forced through the seam in the aluminum just under the gunwhale chines. This water comes in under pressure from the spray being deflected by the boat as it moves through the water on plane. The rivets on both sides are tight, but in stripping away the old paint, I believe I also stripped away a rubber sealer that had been applied to the seam at the factory.
So the question is, how do I re-seal the seam. The seam is just below the chine seen in the attached picture, where the black painted bottom meets the unpainted side.
Thanks for your suggestions.
Doran
Doran
