Leak in Hull?
texsun
My 96 Larson 174sei has taken on about a gallon of water on the last two outings. I would ride around about 1-2 hours-put the boat on the trailer-remove the plug and about 1 gallon of water flows out. This is a new issue - only the last couple of times. No skiers/tubers coming in and out. I looked under the boat and I can't see anything that indicates a leak (cracks or gauges). How can I identify the source?<br /><br />Thanks,<br />Mark
jimmythekid
Re: Leak in Hull?
water can leak in almost anywhere, i could be a hose on the engine, cracked heat exchanger, oil cooler, bellows, gaskets, hull breach, deck to hull joint, like i said almost anywhere just have top look real close all over the boat, good luck
