Leak in the boat.
vasy
This is the 1995 Cobra SX (Volvo SX), over the winter I changed gimble bearing, exhaust and u-joint bellows.
I don't remember having the leak last year unless I missed it, but I don't remember accumulating that much water, but there was a bit after runs.
This year I just did extra careful check as this was the fist run of the year.
I've tried filming with an phone camera but this is of course upside down using a selfy stick: https://youtu.be/pFT30o4D5ac
The water seems to come in all the way at the back, engine does not need to be running for this to happen.
I did a few minutes of driving and came back in,
Remove the drive to check, and the u-joint bellows were dry.
Can I be like Rubber Transom Seal leaking or what else can be there? I'll try taking a better video and ill have my phone charge the next time.
if the rubber transom seal is leaking, your transom is rotten
old-outboard
Just wondered if you punctured the shift cable hose during installation. This will cause a constant drip or leak in your boat. You usually need to pull the motor to repair.
ab59
Ensign
I'm not an expert like many here but I can tell you that I had a leaking transom as well . The transom seemed really solid and I did not want to believe it was bad . I checked the Transom shift cable tube but saw nothing. I then took some waterproof silicon and ran a bead all the way around the outside of the gimbal housing making sure that I did not miss any places . The next day I took it to the ramp and bingo , no water leaking even after 45 minutes .
It makes a mess to remove but will tell you if that is your problem and if it's not the cable tube its almost got to be the transom. I guess you might run with the silicon for a while , but myself , I just could not stand the thought , it looks pretty corny and if you run in salt water it may eat the sealer away.
just a thought--------A.B.
