Leak test lower unit
cloumar
With how much pressure (PSI) should I leak down test a lower unit on a Chrysler 8 hp - 1973 ?<br /><br />Thanks <br /><br />Mario
ob
Re: Leak test lower unit
smokyforce,Around 10 psi is a thumb rule of what seals should hold at.
rons boat
My leak tester recommends 5 lbs for 10 min. Leaks usually show up pretty quick.
bossee
Hi smokyforce,<br />This is the recommended procedure for my Suzuki<br />DT65 so it might or might not apply for a smaller<br />outboard like Yours, use it at Your own risk:<br />
<br /><br />/Bo
cloumar
Thanks to all of you guys, as usual always with a good answer.<br /><br />Mario ;)
